Aug-FUN RUN
    Aug-FUN RUN
    We had a great day and a special guest!!
    All the way from the great state of PA!!
    None other than the Subcommittee's own offical peon Jim Butt!!
    I will post more photos but here is one of a mass of subs escorting a BB63 through dangerous waters. BD.
    Re: Aug-FUN RUN
    Here's some more pictures from that great day.
    CI lost his boat in the weeds, but was able to return the next day and retrieve it successfully.
      Re: Aug-FUN RUN
      Here are a few more photos. BD.
        • 365
        Re: Aug-FUN RUN
        Thanks for posting the pics Guys (and Patti).I didn't have my camera with me.I know I had a good time, now to fix the bugs I had and figure out what to bring next month.Greg
        • Rogue Sub
          • Jul 2006
          • 1724
          Re: Aug-FUN RUN
          looks like toot needs to be renamed the tinkle
            Re: Aug-FUN RUN
            That happens to the best of us when we get older. BD.
            • crazy ivan
              • 659
              Re: Aug-FUN RUN
              Still more photos:
              sigpic
              -George Protchenko
              • crazy ivan
                • 659
                Re: Aug-FUN RUN
                The Rescue:
                The Rescue Tool.
                The golf ball size glob of green gunk enveloping the prop was itself enough to anchor the boat in the depths.
                The massive amount of seaweed draped over the hull sealed the deal.
                There was only a bit of moisture in the control room after 24 hours submerged.
                The engine room did contain less than a teaspoon of water from a known leak.
                Shortly after her loss I could place my ear to the pond surface and barely hear the propulsion plant responding to throttle commands. I could also detect the faint thrumming of the dive compressor when that signal was sent. But I could not determine distance or direction. 24 hours later these sounds could not be heard; the lack of any RF reception overnight ensured that the failsafe circuitry kept the blow valve energized until the battery was exhausted.
                When the boat was located the next day after a 3 hour search, it was about 25 feet off shore in 8 to 10 feet of water, and 180 degrees from the direction she was last seen traveling. Given the amount of vegetation that came up with her, I can envision no method of failsafe design that would have allowed the hull, or even a marker buoy, to reach the surface once ensnared. After a drying out period, the battery was recharged and all functions were found to be in working order.
                sigpic
                -George Protchenko
                • redboat219
                  • Jan 2005
                  • 523
                  Re: Aug-FUN RUN
                  Crazy Ivan,
                  Nice to see you successfully recovered your boat. Just curious as what are those 2 gray cylindrical objects connected to the yellow tubings in the stern.
                  Redboat
                  • crazy ivan
                    • 659
                    Re: Aug-FUN RUN
                    Those are auxiliary air tanks for the reverse RCABS system. The main pressure vessel (the copper ball in the bow) needed just a bit more capacity added on to give me a better surfaced waterline.
                    sigpic
                    -George Protchenko
