Pod mounted motors..?
  • u-33
    • Jun 2008
    • 309
    I'm after a pair of pod mounted motors to go on the sides of Seaquel 5, something about the size of a Mabuchi 380. Must be complete with pods and more or less ready to install. I need them to be able to swivel about 45 degrees and preferably independently controlled.
    Any ideas as to where I can obtain a couple?
    Cheers,
    Rich
  • Rogue Sub
    • Jul 2006
    • 1724
    Please try to make this
    Please try to make this post only once. The three you made are excessive and unnecessary.
    Thank you.
    • Wheelerdealer
      • Jun 2006
      • 315
      Norbert Bruggen sells motor pods
      Norbert Bruggen sells motor pods http://www.modelluboot.de/
        I think they'll be a
        I think they'll be a bit too chunky for his submersible craft.
        Why don't you make your own?
        Fit two subtech seals in some old 35mm film canisters (speed 400 size I think), or run a brass bush with some silicone tubing on the end. Simple and cheap.
        • u-33
          • Jun 2008
          • 309
          Problem solved now, thanks guys..
          Problem solved now, thanks guys.. I've come up with a new, easy to build system which will give me two completely independantly controlled pods capable of revolving through 45 degrees, powered by two 380 sized motors.
          Thanks for the input guys...
          Rich
